To run, 2 * 36 volt 10 ah lithium battery's, with a 72 volt controller with 250 watt motor. I want to drop the AMPS down though, so the amps received by motor is the same power rating as fully charged 36 volt battery (40volts continuous) cheers
Why do you want to run 72V through a 250W motor?To run, 2 * 36 volt 10 ah lithium battery's, with a 72 volt controller with 250 watt motor. I want to drop the AMPS down though, so the amps received by motor is the same power rating as fully charged 36 volt battery (40volts continuous) cheers
Looking to increase range without having to swap Batterys and Maintain stable/continues 40v voltage. Im not looking to increase top speed.Why do you want to run 72V through a 250W motor?
Most 72V systems are for 2KW kits.
Got it sorry new to all this just put plus to plus. negative to negative.To double the range, you connect the two batteries in parallel, that's it.
thanks would there be a way of charging both at same time via 1 charger or would that put to much strain on single charger. ? Cheersyes, charge up the two batteries to full before linking them together. There won't be any spark.
thanks man its all making sense.To charge both batteries with same charger overnight, you can daisy chain the spare battery output to the primary battery charging port then plug the charger to the charging socket on the spare battery.
I made a daisy chain cable with a lead canibalised from a dead charger that I was given and anderson connectors.
Shemozzle999 posted a link to suppliers of charging plugs sometime ago,
http://www.pedelecs.co.uk/forum/threads/bargain-buy-parts.17699/#post-218889
