The sma's are made by jst company china, ebay or various such sites should sell them. The dj7061 is an automotive connector again commonly used on ebikes again one just has to search for them. cost about £2 - £3 each.
Chop the bullets off and solder an xt30 or xt60 on instead.
Hello NealH
Thank you for your reply and the information. This is the controller:
6 fet 15A KT sine wave brushless controller. PLEASE NOTE: This is a sensored brushless motor controller. Your motor should have 8 or 9 wires in order to function with this controller. If your motor only has 3 wires, you will require a sensorless controller. Although this controller can be used...
torquetech.co.uk
As to looking on Ebay - yes, I done that, and other places, but i was wondering if they are all of equal quality, or whether some should be avoided. Guess they are all the same then.
"Chop the bullets off and solder an xt30 or xt60 on instead." - I wondered about chopping and soldering, but had a concern that perhaps the heat travelling back up the wire might hurt the internals of the controller. Guess not then. So if soldering is going to be ok - i could take that approach to all the terminals, and in fact, could dispense with terminals all together, but instead connect to the ancillaries via solder and heat-shrink. Or, connect it all up via those old-fashioned screw terminals , e.g. this sort of thing:
Connect and manage cables easily with this 12-way connector strip. A flexible and transparent polyethylene design makes the strip incredibly easy to work with – a must-have in any electrical toolbox.• 30A 12-way connector strip• Quick and easy connection of cables• Polyethylene works up to 80°C•...
www.toolstation.com
Cheers
