Mystery white wire from rear motor hub
Cancunia
52
I discovered a stray, unconnected white wire from the motor hub on my Batribike Breeze. The wire was loose in the controller compartment behind the pedal crank. The wire has what looks to be a broken connector or tag crimped on the end, but there are no missing connections on the controller that I can see.
Any clues as to what it's for?
Cancunia
52
Aha, so does this mean that someone has de-restricted it in the past? Any ideas what it should be connected to?
Cancunia
52
Thanks for the clarification
It has an LCD display for the battery level but no speedo / speed indicator. Presumably the speed limit is somehow sensed by the controller?
3,986
It doesn't do anything other than give a signal for the speed display. Without a speed display, it has no effect on speed or de-restriction. When that wire isn't connected, the controller gets the speed from the timing hall sensors.
