PAS Wiring Question
Warwick
731
225
Warwick
My Pando Pro kit's PAS Sensor has a very short cable. Too short for the proposed place the controller is going to sit.
I have an all-in-one Kunteng BB-fitting PAS - the type that slides into the BB splines. It has a much longer cable that would fit my plans and is a far better solution IMO.
A workmate has offered to do some soldering for me & I asked if he could also solder the Panda connector - a handy yellow plug, onto the Kunteng's wiring. Yes, no problem.
However, when we cut the cables the Panda had 3 wires; white, red & black, whereas the Kunteng's were brown black & yellow. Now, I assume black fits black and I'd guess that brown fits red, leaving the yellow to fit the white. Would those assumptions be correct?
5,785
d8veh posted the equivalent a while back, I think you are correct. You can test before you commit to solder.
Warwick
731
225
Warwick
Thank you both.
