Problems after replacing freewheel
Keldin
25
53
So I'm not sure what the problem actually is so I'm afraid this may take a while to explain (sorry).
I have a Mezzo that has been converted with a rear hub motor. The 9-speed freewheel cluster was replaced with an 8-speed in the process and all was fine. I only had it after it was converted.
I then replaced this with another 8-speed from d8veh as I wanted 11t not 13t.
Since replacing this I now have the following problems:
The wheel is extremely difficult to remove and replace - the dropout seems too narrow for the hub. This was the case with the old 8-speed freewheel and you have to prise the wheel out or back in.
The wheel used to spin quite freely and now it slows and stops after a few turns (brake is not touching).
There is a noticeable 'notchiness' when turning the wheel by hand even without the chain on it.
The rear derailleur now sits even closer to the sprockets almost touching. I can't seem to adjust it away. It i snot however the source of the notchiness noted above.
There a squeak when turning the wheel.
It seemed a simple enough swap except for the problem with the wheel not fitting the droupout so i'm not sure if I've messed up or if its just not going to work with the new freewheel. Even if I have to go back to the old one the spacing seems like a problem.
Hopefully that makes some sense and not too much rambling.
You need an extra washer on your axle. It sounds like the freewheel is touching your frame. Make sure the washer is small enough so that it doesn't touch the freewheel too. A standard 12mm washer should be OK in that respect for A DNP freewheel because the inside diameter is quite large.
Keldin
25
53
Hi d8veh
Thanks for the quick reply.
There's a good gap between the freewheel and the frame of a couple of millimeters. I cannot see anywhere that it is touching. Even if it were I'm not sure I could even get a washer in there as I already have to lever the frame open to get the wheel in.
Is the freewheel touching the side-plate of the motor then, in which case you need a freewheel spacer?
Keldin
25
53
No there's a gap there as well. The rumbling/notchiness as when i turn the wheel backwards so the freewheel moves as well and the squeak is when I move it forward.
When you turn the wheel backwards, it turns the motor, which is probably what you feel.. When you turn it forward, it freewheels.
The squeak is probably the brake.
To adjust the derailleur, there's a screw on the back by the hanger.
Keldin
25
53
Is that normal? I'd not noticed it before.
The brake is disconnected when it squeaks. Not touching at all. It seems to be coming from the hub/freewheel.
I've tried that screw. It doesn't appear to shift the derailleur at all. :-(
Alan Quay
2,351
1,076
Devon
You can feel notchiness if any of the phase wires are shorted together. Just a thought.
Alan Quay
2,351
1,076
Devon
I just mean that if you have the wires disconnected, ensure they aren't touching each other. I suppose there's also a slim chance that you have a damaged cable where you took the wheel out.
30,388
These motors are always notchy when turned backwards, since the internal freewheel is locked then. It's just the rotor magnets tugging at the poles as they pass.
If your phase wires are touching, you can hardly turn the motor. You're feeling the normal motor turning.
The freewheel can't squeak. When you pedal, everything goes round with the wheel. The only possibility is that you have a washer touching the inside, but, as I said before, it has a large hole in it, so plenty of clearance for a standard 12mm washer.
Keldin
25
53
Ah ok that may be it. It's just something I never noticed before even though it now makes a loud enough noise when the wheel is turned slowly. Maybe I need to find another one to compare.
The squeak when going forward is definitely new.
