Puncture repair?
bigclick
206
52
63
ive been away and just checked out my KTM in the garage and the rear tyre is virtually flat.
Not sure of the full spec but I'm pretty sure the tyres are tubeless?
So how do I go aboutb sorting this out? Anyone any ideas?
D8ve
2,142
1,294
Bristol
Sheldon brown is the best source of General bike maintance advice.
Search and read his online guide.
Reactions: bigclick
SRS
847
347
South Coast
You will most likely find that the tyres are of a tubeless version but tubes have been fitted.
Remove and repair the tube or remove the tube, get a fit a tubeless valve and some sealant.
Either way, you will need to remove the tyre initially.
EddiePJ
4,632
4,012
Crowborough, East Sussex
www.facebook.com
bigclick, you will find that the tyres aren't tubeless.
I initially thought just the same. It actually states 'tubeless ready'
What you have probably already discovered, is that the tyre bead is stuck fast to the side on the rim, and this was exactly what lead me to think that they are tubeless. Give the side a really hard squeeze and the bead/seal will be broken.
The rest as the say is easy, and the through axle makes dropping the rear wheel out a pleasure. Release the clutch mechanism on the rear derailleur first if you have it set, and select the smallest cog on the cassette before trying to remove the wheel. There is no need to remove the brake pads, and obviously don't touch the brake lever whilst the wheel is out. Refitting is just as easy as removal. :)
Watch that the cassette and free wheel hub also don't drop off. They are press fitted and I was caught out with this one just a couple of days ago, and ended up with the bits all over the floor. An odd thing to happen given that I take the rear wheel out when I clean the bike after every ride. It just gave me a bit more to clean, and in a way makes maintenance even easier.. :)
I now just need to buy the correct/recommended Swiss DT grease.
Reactions: bigclick
RobF
4,732
2,311
It's very easy to accidentally squeeze the brake lever, particularly if you have the bike upside down.
Quality bikes (!) like my Rose come with a bit of plastic to shove between the pads when the wheel is out.
If you don't have the Magura Transport Device, a bit of folded cereal packet will do just as well.
Reactions: bigclick
bigclick
206
52
63
I have the blue plastic spacers havent used them though.
I blew the tyre up and looked for bubbles didnt find any and the tyre wasnt going down. so its probaly a slow punture. Now I know its a tube il fix it as "normal" I thought they were tubeless foir the very reason Eddie pointed out, the beads seem stuck solid.
If it hasnt gone down tomorrow then it might have been a loose valve (new bike syndrome)
Also found a loose spoke today on the front wheel, I gave it a few turns with the spoke tool, I dont think thats over the top is it?
bigclick
206
52
63
[quote="EddiePJ, post: 244944, member: 10334" An odd thing to happen given that I take the rear wheel out when I clean the bike after every ride. It just gave me a bit more to clean, and in a way makes maintenance even easier.. :)
I now just need to buy the correct/recommended Swiss DT grease.[/quote]
youtube says the DT Swis are toolless?
RobF
4,732
2,311
Fill a bath with about five inches of cold water and slowly run the tyre through it.
That ought to show any leak, particularly if you make sure there's plenty of air in the tyre before you start.
The spoke needs to be a similar tension to all the others.
Judging that comes from experience, but you may get an idea by plucking some other spokes and judging if the tightened one feels - and sounds - the same.
EddiePJ
4,632
4,012
www.facebook.com
It is. :)
You still require a cassette/bottom bracket tool to remove the cassette from the free hub body though.
If your cassette etc does come off, it's no big deal, but just make sure that there is no grit or other debris between the faces of the components when you press it back on again.
edit....I've just looked at the price of DT Swiss ratchet grease!!!!!:eek: You need to re mortgage to buy it.
Reactions: bigclick
bigclick
206
52
63
Thanks Rob, I'l give that a go when her indoors aint around.
I think I matched the tension of the other spokes.
Question: They dont feel super tight to me, Is this because they're quality wheels? They make a note if I tap them but not a full on ringing note.
RobF
4,732
2,311
Sounds (ho-ho) about right to me, assuming the wheel is reasonably true.
I take it all the spokes cross, the friction at the cross helps to stop the spoke 'unwinding' in use.
Radial and parallel designs look flash, but are not so clever in other ways.
bigclick
206
52
63
yes they cross thanks again guys
Aushiker
Fill a bath with about five inches of cold water and slowly run the tyre through it.other spokes and judging if the tightened one feels - and sounds - the same.
Warm water (well as hot as you can make it) works much better than cold water as it heats up the air and thus really hard to find holes will show up.
Only way I could find leaks in my Exped Synmat UL 7 was through the use of hot water ... nothing showed up when using cold water.
Andrew
bigclick
206
52
63
its been three days and no discernible loss of inflation :)
I am hoping this means it was a loose valve
D C
1,140
575
I'd still be removing it to check, as you know that it will fail at the worst possible time.
It'll only take you minutes. :)
I'd second that, good for practice and easier at home than the inevitable dark and rainy day when it will fail at the most inconvenient place just after riding through a pile of you know what.
Dave.
Reactions: EddiePJ
