RST Fork pressure
Mantis55
21
68
Midlothian
Recently got a Kalkhoff Advance I10. According to the specs I've got RST Pulse LO forks, 80mm travel.
Looking at the RST website, the Pulse forks are only for speed pedelecs, although mine isn't, and mine is 50mm travel, the only info I can find on the forks.
However it looks like the Pulse from the photos, probably the middle one (27.5") as I have a 700c wheel size. Any ideas about pressure for this fork?
Mantis55
21
68
Midlothian
Thanks for that. Looks like I assume it's closest to Trekking (Vogue air) as all the other types are miles off the pressure? Is 110-120 a typical pressure for a trekking type e-bike then?
6,319
you set the sag to ur waight on the bike but its up to you how hard or soft you want it.
Mantis55
21
68
Midlothian
Yeah I get that, it was just a query because the psi in the table you sent is much higher for that one type of shock. Cheers:cool:
