Solar Charging ?
jeff St.Clair
53
20
71
Crete
OK here's a thing ..this summer I fitted a conversion kit on y Specialized Rockhopper and it's great, had a few teething troubles but now it works great fast enough , powerful enough to get up the hills, feels safe and rock solid ...So as it is very sunny here ,I thought how about extending the project into making the bike solar powered ...with a photovoltaic panel on the roof of my workshop ...where I keep me bike ...what I can't decide is ...do I fit a panel that charges deep cycle leisure batteries connect them to an inverter to make 240 volts then plug the 36volt charger into that.... or have a set up that just makes the 36 volts to charge the bike battery .. Has anyone done this ? This project is in the early planning stage so any input is useful ...point out pitfalls please....proper planning prevents poor performance ....
30,852
E-biking enthusiasts A to B Magazine did this and found the best results from having shed roof panels charging leisure batteries.
They've covered this subject in various issues but the main one I believe was issue number 37, contents on this link
They will send you the article free on application to:
A to B Magazine
__________________________________________
40 Manor Road, Dorchester, DT1 2AX, UK
atob@atob.org.uk
atob@onetel.com
01305 259998
+44 1305 259998
Fat Rat
1,903
726
UK
I would have said battery storage from the panels as well
You will get a much more stable voltage that way .
jeff St.Clair
53
20
71
Crete
Thanks for the response ....I think batteries and inverter is the way to go ...up here in the mountains having an off grid 240 volt supply could also get used for other stuff ,in a not infrequent power outage ......
KirstinS
3,224
899
Brighton
Just be a little.careful, some members have had issues using their mains chargers connected to lesuire batteries and inverters
Indeed I have killed a charger by connecting it to cars inbuilt 240v supply (clearly via an invertor). Car is a Ford smax though prob not relevant
