What does % Support mean?
Gilbert
7
59
I have a Giant Full E and the literature says it gives up to 300% support. Can anyone tell me what this means? Does it mean that if I am putting in 100W it is giving me another 200W to make 300W in total?
  • Useful
Reactions: LeighPing
6,722
in max assist mode it will be 300% from motor and what ever you can put in on top.
thus why if you have a dongle you will spin out as ran out of gears at max rpm
Reactions: flecc and LeighPing
5,786
so if I have a 250W motor is it going to give me 750W?
That is correct. About 720 W peak of it has a 20 Amp controller.
17,232
that means if you put in 100W, the motor 300% of your input, 300W, the bike gets 400W.
100W is good pedaling. The motor is capable up to 600W, this is roughly indicative of a 20A controller.
It also means that if you are very atlhetic, the bike will not offer more if you exceed 200W of your own input.
30,806
Not necessarily, the maximum the motor and controller can give is the limiting factor.
It will give 300% up to the motor's limit, but not beyond.
17,232
How does it know how much support to give?
the torque sensor measures how much force you put into pedaling. The formula is: Power = force * radius * 2 * pi * sin(angle) * (cadence/60) * support ratio
Reactions: Gilbert and JPGiant
Gilbert
7
59
Thanks for the explanation Woosh (just need to go and brush up on my maths and physics now!)
