What gauge and type of wire to use for main power
TheBikeMan
58
Cardff UK
Hi,
What gauge and type of wire are you guys using for the main power and for the cable for your C- P- B- from your BMS when you rebuild batteries?
It seems every time I open and older battery there is a different size wire in them.
8,754
Depends on the cell amp rating and the controller rating/amp draw.
Using thicker rated wire is for safety as it will run cooler and prevent bottle necks when a load is asked.
For P- & B - I use 14awg ( about 45a rating) and also the same on + connections, though you could use 16awg (about 32a rating).
For C- & C+ I use 22awg (7.5a rating) as my charge rate is never more then 2.3a.
If considering fast charging using 4 - 8a then consider 20awg ( 14a rating) for C wiring.
Some BMS come with tails soldered on the board so I extend these if need be.
For sensing I use 22/24awg.
KirstinS
3,224
899
Brighton
Do you have a favourite supplier Neal ?
8,754
No, If I need any I just use a supplier off ebay for silicone awg. I have used HK when buying lipo but no longer use them at all.
