Hi
Can you tell me if any of the spare connectors in the controller box are available to power lighting? If so what voltage do they operate at and what current are they capable of passing? If not of course, ignore the latter!
I find that I use the pedelec mode whenever I am travelling slower than it's maximum (eg. up a steep hill), but if I require more assisted speed I usually just have the throttle on full whilst pedalling. Under these circumstances it would be much more comfortable to ride if the throttle assembly were replaced with a simple 'boost' switch, basically just going straight to full throttle. Is it possible to rewire the throttle into a switch arrangement to do this? If possible it would be ideal (and much safer) if the boost system would not operate until the motor had already been started using the pedals.
Cheers, Phil
P.S. Still no news of those new design brake levers?
Cheers, Phil
