drive chain
the drive chain from my motor to the bike , varies in tension and keeps coming off the large sprocket, its an 8mm chain, does anyone know where I can get a jockey sproket to keep the tension more even?
thanks
bob
Here's two sources Bob:
Wiggle
Bikedock
These are made for derailleur point attachment, so you'll probably have to rig a frame clip to mount them. Hopefully they'll be wide enough for your chain.
Chain Tensioner?
thanks
bob
Hello Bob:
Is this what you need?
hit the link to SJS Cycles (there may well be other suppliers):
Search Results
You may have to enter "Chain Tensioners" in the search box under "Transmissions".
I think your chain will be 3/32 inch. Cycle Chains and their pitch have remained steadfastly imperial I think.
Peter
There is here a link to "Derailleur Hanger which might just prove useful:
Click the link - if it does not take you to it, enter "Shimano Gear Hanger" in the search box.
Search Results
Edited by ITSPETEINIT
