Battery mounting plate
Hello there,
Anyone know where I can find a battery mounting plate with quick release and key without buying the complete battery for 200GBP?
I know they sell that in bmsbattery:
http://www.bmsbattery.com/battery-case/674-48v-15ah-lithium-ion-alloy-shell-ebike-battery-pack.html
But it seems you also need to buy the rear rack from them and the shipping cost is higher than the battery itself!
Grin have a battery anchor listed on their website.
http://www.ebikes.ca/media/catalog/product/cache/1/image/d33f8bafbb033e6f66b003faca9e0ee7/B/a/BattAnch.jpg
Andrew
Andrew
I was looking at these earlier - they're out of stock - no indication when (or if) they will be back.
They are, well the black ones are, available from Glow Warm Bicycles. Don't know how the pricing works out but or if they will post to the UK but.
Andrew
Thanks Andrew. I've asked the question.
If they say no I am happy to on forward to you at cost.
Andrew
Andrew
Thanks,
I'll bear that in mind. At the moment it will be in a pannier bag.
Andrew
Had a reply from Grin; they will be producing more soon, and are happy to sell to UK. :)
Andrew
The one from Grin looks interesting. But I'm not sure how it would work on a frame? Any idea how to mount it to a frame with the mounting clamp and a quick release?
Sounds like you are sorted :)
Andrew
Cwah, I think you are misunderstanding. The plate from devimotion/bms battery/golden motor are nearly identical. They fit the extruded alu battery box from your opening post which has a locking mechanism in the battery end doubling as a power key switch. If you don't own the battery in the original post then the grin one is probably the way forward. The key belongs to the battery not the plate.
