November 4, 201510 yr Does anyone know much about these bikes? the Joules micro prism? Considering byt unsure of spec? cheers Pete
November 5, 201510 yr I have not tried it but from the general innformation given by the company, it's a very good product with high tech NuVinci hub gear. The motor, controller and battery are all good. The bike is striking in looks, a compact bike (it does not fold) and heavy (24kgs) because of the N360 but the weight is well distributed. I thought you were offered two for the price of one, then it's excellent value for money.
November 10, 201510 yr Author I have not tried it but from the general innformation given by the company, it's a very good product with high tech NuVinci hub gear. The motor, controller and battery are all good. The bike is striking in looks, a compact bike (it does not fold) and heavy (24kgs) because of the N360 but the weight is well distributed. I thought you were offered two for the price of one, then it's excellent value for money. yes i was offered 2 for 1300.00, but supplier is not a familiar name so worried about after care/support. Under another name, rather than joules micro. would it be better than woosh gale with 13 amp battey? or the ebike very similar spec to woosh?
November 10, 201510 yr Joules have been around for a few years but your guarantee is with the vendor. If you don't buy directly from Joules then there is less certainty, you may need to clarify the terms of guarantee with the vendor. The electrical side is fairly standard, the bike can be fixed by most trade members of the forum. If you like the look of the bike then go for it, the risk is small. When you get the bike, check the motor manufacturing date, it is usually printed just before the motor serial number. It will give you a pretty good idea when the bike was made and imported, hence the life expectancy of the battery and the likelihood of the vendor continuing support. More recent is better.
November 10, 201510 yr Author great thanks, the company tell me the stock is 2 yrs old so, if never used is battery likely to be knackered?
November 10, 201510 yr Can you test ride before buying? otherwise, you may have to take a chance on this - batteries can last 4 years if used regularly.
November 10, 201510 yr Author Can you test ride before buying? otherwise, you may have to take a chance on this - batteries can last 4 years if used regularly. Thanks, still sitting on fence this or woosh folder with 13amp battery.... never pondered so much as over one of these bikes.....so expensive and fear of getting it wrong.....lol
November 10, 201510 yr Author Thanks, still sitting on fence this or woosh folder with 13amp battery.... never pondered so much as over one of these bikes.....so expensive and fear of getting it wrong.....lol and no i cant test ride....
