June 4, 20178 yr Hi everyone The market is confusing with hub motors, I am looking for a rear mini hub for stealthiness, . I am in the UK so carrige charge might be high, so dont mind just buying the hub unit. so think what it must be able to do is 250w or 350w good power 48v ? take a 9 speed (cassette or freewheel) what would you guys buy given the option. Thanks Andy
June 4, 20178 yr Don't know anything about it, but the item in this adjacent thread looks ideal for stealth, looking more like a hub gear than a motor. .
June 4, 20178 yr Q100H. If you want a bit more power/Torque at the expense of weight, the Q128C. The smallest/lightest cassette motor is the Keyde, which has an internal controller, so isn't so easy to fix when it gets a problem, and they certainly used to get problems. I don't know if that's been improved now.
