June 4, 20196 yr can anyone help my sduro is reading under on distance travelled by between 4/5 % this has been verified using gps and three other e/bikes is it possible to re-calibrate ? many thanks
June 7, 20196 yr Author I have checked the manual but their is no procedure for setting the wheel diameter does any one have a procedure for setting it????
June 12, 20196 yr It seems that they designed the computers to be very unfriendly and only an authorized shop can make any changes to the settings. If you changed tyre sizes , you may have to pay for any changes, if the tyres are the same, it should be under warranty, (if applicable)
June 14, 20196 yr Cars are the same. Does it really matter? Now you know what the disparity is you can allow for it.
