October 9, 20223 yr Its the second or third item discussed on the video, but not the first, and what comes up after that I have no idea, YET!! I hope they are also interesting! Regards to all Pedelecers and stay "SAFE"! Andy and https://bestgadgetadvice.com/25-gifts-en/?sxid=am07p87m78n8&adid=end1&campid=end&ttorigin=am07p87m78n8 Edited October 9, 20223 yr by Andy-Mat
October 9, 20223 yr Thanks [mention=20993]Andy-Mat[/mention] for suggesting that I use a Oxford Lollipop side reflector. I tried it out for the first time today, and I am happy to report that most drivers did seem to allow me more room than usual. Very good tip! https://www.amazon.co.uk/Oxford-Fold-Out-Safety-Reflector/dp/B004H1QYG2/ref= The product above will only fit on a thin horizontal thin bar. I've fixed it to my rear rack... the only issue I have with this particular incarnation of the idea, is that it isn't resistant enough to wind; doesn't maintain a right angle to the frame. I may make a thin rubber washer using old inner tube, because using a small hose clamp to increase pressure didn't work for that, but it did make the lollipop clamp which attaches to the bike rack secure enough to keep it horizontal . Perhaps I can also roughen that lollipop end at the clamping point with sandpaper, to add a bit of friction, or something. But it's a small fixable niggle. [ATTACH type=full" alt="49104]49104[/ATTACH]
October 10, 20223 yr Author Thanks [mention=20993]Andy-Mat[/mention] for suggesting that I use a Oxford Lollipop side reflector. I tried it out for the first time today, and I am happy to report that most drivers did seem to allow me more room than usual. Very good tip! https://www.amazon.co.uk/Oxford-Fold-Out-Safety-Reflector/dp/B004H1QYG2/ref= The product above will only fit on a thin horizontal thin bar. I've fixed it to my rear rack... the only issue I have with this particular incarnation of the idea, is that it isn't resistant enough to wind; doesn't maintain a right angle to the frame. I may make a thin rubber washer using old inner tube, because using a small hose clamp to increase pressure didn't work for that, but it did make the lollipop clamp which attaches to the bike rack secure enough to keep it horizontal . Perhaps I can also roughen that lollipop end at the clamping point with sandpaper, to add a bit of friction, or something. But it's a small fixable niggle. [ATTACH type=full" alt="49104]49104[/ATTACH] I like the fix, simple and easy to achieve, once the idea springs into the old brain box! And I am really pleased that you stuck with it, and that it also keeps the traffic a bit farther away. SAFETY FIRST! Regards Andy
October 12, 20223 yr I like the fix, simple and easy to achieve, once the idea springs into the old brain box! And I am really pleased that you stuck with it, and that it also keeps the traffic a bit farther away. SAFETY FIRST! Regards Andy Because that small hose clamp holds the lollipop so rigidly horizontal, I have drilled through and tightly ziptied an otherwise useless flashy mount and flashy to it. This flashy was formerly affixed to my seatpost, before the other part of it's mount broke. It might even stay on, we'll see. It's a light light, therefore the lollipop may remain horizontal in use. [ATTACH type=full" alt="49136]49136[/ATTACH] [ATTACH type=full" alt="49137]49137[/ATTACH] Edited October 12, 20223 yr by I893469365902345609348566
October 15, 20223 yr I'm pleased to report that the flasher stayed on, even though it was raining for 10 miles last night. The lollipp stayed horizontal and the rubber small washer I made out of old inner tube for the horizontally swivelling end, kept it solidly outward pointing. What's made me even happier is, the flasher addon has made this Oxford Lollipop even more effective! During the rush hour 10 mile trek, only two cars passed too close, which is a vast improvement. They allowed me much more space passing, than when the lollipop was without flasher, although many did swerve too close to the front of my bike afterwards.
