Brake disc wear
The wife has a 2022 Gazelle ebike with 5-speed Nexus hub and Tektro discs. Because of the steep hills round here and also the way she uses her brakes, I'm thinking ahead to the point at which it becomes obvious that her rear disc in particular is past its best before. So ...
Q1 Is there a generally-accepted minimum thickness for ebike discs?
Q2 Is it feasible to fit a new disc to a Nexus-hub wheel, or will it be a case of a new wheel?
Have a look at
https://bike.shimano.com/en-EU/product/component/ep8-ep800/SG-C7000-5D.html
and if it is that one, it takes a 'standard for shimano' centre lock brake disc. You need a special tool for the locknut, usually an externally splined one, same I think as the spline pattern on Hollowtech II cranks, but sometimes an internally splined one same as a cassette tool, and it will be quite tight so take care and get help if needed to undo it.
There are many different discs, from about £12 upwards for genuine Shimano. I use only Shimano brake pads on my M200 brakes, B05S being the latest, which are about £9 a pair, and after 4 sets and over 9,000 miles I am considering a disc swap next time the pads need doing. Many Tektros use the same pad shape, and if so I have tried several and none match Shimano for quiet, powerful, fairly cheap, decent lifetime.
From Shimano website
https://bike.shimano.com/en-US/information/news/tune-up-guide---mtb--disc-brakes.html
Braking erodes material off the rotor depending on the riding conditions, rotors will typically last through two or more sets of brake pads. When a SHIMANO rotor measures 1.5mm thick or less, it's time to replace it. A new rotor should always be accompanied by new brake pads.
Diisk rotors are either 6 bolt or centrelock fitting, if using 6 bolt tighten the bolts in a star shape pattern, this stops putting excess pressure on one side of the disk. I also give the bolts a clean with isopropyl alcohol, and apply fresh threadlock. Some people use a torque wrench, if doing this tighten each bolt half the recommended torque setting then tighten full torque setting.
https://www.bikeride.com/torque-specifications/
Its a good idea to have and use a torque wrench, and they arent too expensive.
Thing is many people are heavy handed and if you overtighten you can crack the hub mount, which then means you shell out a lot of money for a simple and silly mistake.
If you undertighten, theres a chance the bolts can vibrate loose, and once they stick out too far they'll rip the hell out of whatever they come into contact with like the caliper itself or the frame, or in the case of rotors rip the darn thing off the hub when you apply heavy braking.
And all for the want of a £30 tool.
Thanks folks :)
The hub is actually a Shimano Inter-5E and now I've been able to look closer, the Tektro disc is held onto the "spider" with what appear to be countersunk machine screws. Not sure what the correct term is for the type, but instead of having a normal Allan-screw hex socket they'll need a star-shaped bit to shift 'em. So it looks like the discs themselves are a doddle to change.
Although the discs are Tektro, Shimano's 1.5mm minimum's good enough for me. We do use Shimano pads, btw - just got a batch of BO3S from Rutland Cycling at a good price which will keep us going for a few years ...
It is a T25 torx bit you need for the bolts, buy a good quality bit, I like Wera stuff
<snip>
When I collected my Wisper 705 the original owner used a little torque wrench set when he dismantled the bike enough to get it onto the rear seat of my Jaguar S-type. I was so impressed that I ordered the same torque wrench set from Wiggle the next day.
https://www.wiggle.co.uk/lifeline-essential-torque-wrench-set-1?utm_source=order-placed-sg01-en&utm_medium=email&utm_campaign=orders&utm_content=product
Why on earth would anyone use a torque wrench to unscrew fasteners?
