September 19, 2025Sep 19 Hi The back wheel won't spin freely. I was wondering if this is because of the magnets.
September 19, 2025Sep 19 It should spin freely - something maybe rubbing - brakes ? Turn it upside down and look carefully and see if you can identify what is rubbing against what
September 19, 2025Sep 19 Author It should spin freely - something maybe rubbing - brakes ? Turn it upside down and look carefully and see if you can identify what is rubbing against what Thanks Peter. I had to remove the back wheel to put in a new inner tube. That must have caused it. So the wheel should spin freely just like on an ordinary bike? I forgot to mention the bike is a Carrera Crossfire.
September 19, 2025Sep 19 Did you put the washers on the axle back in the same position / configuration ?
September 19, 2025Sep 19 Good question. Possibly not. I'll investigate. Many thanks. A Crossfire wheel should spin just like a normal bike but only in the forward direction. When you spin it backwards, there is some resistance from the motor, so it'll do maybe one or two turns from a good spin.
