Hi I have a powabyke I'm doing up I striped it down but got stuck on the crank as it's seased in so with lots of effort I got the locking nut undone that's on the spindle that the peddles go on it's a 22mm spanner that fits the nut it sits next to a washer then the deep nut that holds the bearing in that ones fine but I turned the out side nut the wrong way and threaded it as it's a femail thread it's backwards to the norm. The crank thread is fine as other nut went on and off after greasing up was done but I now need to lock it in place at a push I will ust this nut with thread lock but I'm sure some one out there knows were I can get a replacement. But it has to be backwards thread not normal like me thanks Paul
