I have spelled this out many times, this is only for long term storage, never for a battery in use, and it really applies at a consistent almost zero degrees C. Most household fridges sit at 5 to 10 degrees varying. Actual freezing should never be done, it destroys the battery.
Therefore it will rarely apply to most e-bike owners. If a bike is to be laid up for the winter, yes, but if used fairly regularly, no.
To get the full advantage of the low temperature the battery should be down to about 40% charge, and the stresses of discharging, reducing temperature, then allowing temperature to get back to normal before use and recharging all have their own losses. Doing that regularly would drastically shorten the life.
I use my laptop on battery only about once a year, so it's lithium battery is clingfilm wrapped and in the base of the fridge at the back at around 3 degrees fairly constant. It's now in its sixth year and fine. If I'd put it in and out of cold storage frequently I'm sure it would have been wrecked within a year.
