I have been informed that using a big motor say 750watts it will draw more AMPs from the battery, hence less range. So what would be the best set up to keep the range above 15 miles with hard throttle use and with the added !OFF ROAD! speed of 20mph+
"I know you ALL might be shouting get a 50cc moped, but the bike will be used for the following:- commuting, pedalling in the morning for fitness and getting home as quick as possible, with little or no use of the pedals"
For instance 500w 48v 15ah or 250w 36v 10/15ah or 350w 36v etc etc.
Common sense says I would need big AMP and VOLTAGE ratio as possible, to handle the BIG motor.
Or have I just answered the question myself.....
Finally a lot of people are saying that a 250w 36v 10ah set up will do 15 -20 miles on fairly flat ground with little or no pedalling is this the case.
B0331E
B0331E
