Electric Kit + NuVinci Hub for Sale
Peter_Tandem
13
53
Hi
I have the following for sale
- Pedalease 36v 250w Electric Bike Kit with battery in a 26" front wheel
- NuVinci N360 gear hub
This allows the right hand to control the throttle, and the left hand the bike gears.
It has completed about 500 miles.
The details are below.
I have them all built into a tandem frame so I am looking for
£250 for the electric kit
£150 for the NuVinci gear hub
+£50 for the tandem complete (not the suspension seat post which is extra)
NuVinci N360 continuously variable transmission for bicycles
http://www.fallbroWi-EV-ECoktech.com/cycling/n360
It is currently built into a 26 inch rim.
36v 250w Electric Bike Kit with battery 26" wheel
https://www.pedalease.co.uk/index.php?rt=product/product&path=67_73&product_id=13172318&session_id=b4b3239cb56d952eebdbfbaa8b8fb580
26" 250w 36v ebike conversion kit front hub mini motor with lithium battery
1. 36v 250w brushless front hub motor built in double wall alloy wheel and 2.6mm spokes
2. Half Wrist throttle
3. 36v 250w controller
4. 1:1 pedal assist sensor
5. Seprate motor line
6. LED display meter - with 4 modes ( Low, Medium, High and 6km walk speed mode)
7. Mini 6mofset controller size: 32mm*52mm*100mm
8. good package
9. 36v 11ah lithium battery - bottle holder mount type with USP port 2014 model.
10: battery charger
Electric bike lithium battery this is Li(NiCoMn)O2(NCM).
36V Battery Pack Specification :
1. Nominal voltage: 36V
2. Rated capacity: 11Ah.
3. Lifecycle: 1000- 1200 Cycles with DOD80%
4. Dimension: 34 x 12 x 8 cms
5. Operating temperature: -20 °C to 60 °C
6. Charge temperature: 0 °C to 45 °C
7. Storage temperature: -20 °C to 45 °C
8. Operating humidity: 5% to 90% BMS Specification:
1. Operating current: 10A
2. Peak current: 15A
3. Charge current: 2A
4. Over-voltage protection: 42.5V
5. Under-voltage protection: 27.50 V
6. Over-temperature protection: 60°C
Charger Specification:
1.Output: 42V DC 2A
2.Input: 100- 240V AC (As your country's standard)
battery pack Net Weight: 3kg
KeithMac
344
255
24
York
I'm interested in the Nuvinci rear hub/ wheel complete (with shifter assy).
How much posted within UK?.
Peter_Tandem
13
53
Hi KeithMac
I would have to check tomorrow. I would imagine a wheel complete would be about £15. I can get a wheel box from bike store if you are interested, and you can arrange a courier collection if you prefer.
Let me know what you wish to do.
Just for clarification, it is 32 spoke hub, with custom heavy duty spokes made to measure.
Peter
Warwick
731
225
Warwick
What diameter is the seatpost and how much are you asking?
KeithMac
344
255
24
York
Hello Peter, I would like the rear nuvinci hub/ wheel complete (with sprocket), shifter and cables. Basically everything to allow me to fit it into my Carrera mountain bike.
£20 postage is reasonable if you don't mind packing it up, I use UPS via Interparcel normally. I can arrange courier through Interparcel or pay you £20 p+p whichever is easier for you.
Cheers, Keith.
Peter_Tandem
13
53
Cheers, Keith.
Peter_Tandem
13
53
Hi Keith
Do you know how to send a personal message on forum? Then we can exchange contact numbers and arrange payment and delivery. Tomorrow I will sort a box.
I should mention, nuvinci only do a rhs gear shift, so if you keep the throttle on rhs, then gear display on lhs is upside down , however it is purely cosmetic. I did contact them for lhs shift, but told they didn't do one.
I have original cables since I had to get longer cables for the tandem.
Peter
KeithMac
344
255
24
York
Hello Peter, I will pm you my phone and email in a moment.
RHS shifter is fine, will be using it with normal leg power rather than electric.
Cheers, Keith.
Peter_Tandem
13
53
Hi Warwick
The seat post is 27.2mm and I also bought a softer spring so you can have post and extra spring for £50 ono. It is in very good condition. Can send extra photo if you wish.
Peter
