Help with controller
keastan
Hi
Have just purchased a new 24 volt brushless controller from ecrazyman on fitting the motor runs rough nosy and fibrates when ridden. Is the controller incompatible ? If so can anyone advise where to source an alternative ?
banbury frank
Banned
Jan 13, 2011
1,565
Hi keastan
You have the motor running out off phase swap the green and yellow wires
on the power and hall sensor wires
so the thick yellow wire join to the thick Green wire
thick green join to the thick yellow
then join the thin yellow to the thin green
join the thin green to the thin yellow
leave the blue to blue they are OK
Hope his helps frank
keastan
frank thankyou
Hi frank
thank you so much for your quick reply, you have made my day, I had to change only the thin wires and its working O.K very much appreciated.
