Help! Hi a bit advice please.
Koley
Feb 12, 2021
Hi due to a duff knee i purchased my first ebike a Roadhog RS 1X fatboy and its great! But unless freewheeling im restricted to 15 mph, also the S866 display layout is different (like a lanke leisi) so im not able to tweak any settings that may help. The bike has a 7 speed shimano, the hub/motor is 36v 250w 20" battery 36v 10ah 360wh. The sensor is on the crank, the controller spec is 36v cutoff 29v current limit 16A, display meter 2HAO.
PS i understand all the legal restraints and good in the soldering/ crimping/ harness dept. Cheers.
Koley
Feb 12, 2021
Thanks for your help I may well get one of those, im having a last shot at adjusting the settings on the existing one. For some reason it looks different from the others online. On the setting screen i set the first digit to 8 assuming thats the Program and the other three to 100 and hit the power to save, it doesn't seem to change anything. Thanks for any help.
3,986
It's looking for a number code. The default or emergency one is 3745. If that doesn't work, do all the common ones, like 1111, 1234, 0000, then use your imagination. 19** is very common, presumably somebody's birth year, so start with 1999 and work backwards. Also try 2020 and 2021.
It'll probably be up and down to change the number and power button to enter it.
Reactions: Koley
Tileva
Mar 5, 2023
Finland
Hello!
I have an RKS RSI-X bike and password in that bike is 6666.
It has an S866 display and controller model: X032-AA003
