I've posted in previous threads about this but I think they were more hub oriented, I'd just like to know about the experience of any other panasonic owners with derailer gears.
I've looked at this http://www.pedelecs.co.uk/forum/electric-bicycles/7952-wisper-chain.html and also this Derailer Adjustment
My chain doesn't appear visibly worn and nor do my sprockets, not as detailed here - Chain Maintenance
I've done 2200 Km, which I believe is below the point at which folks typically replace sprockets or chains. I've also measured the chain wear as detailed on that last link and it appeared to line up perfectly.
This has led me to wonder whether this is just down to my chain and sprocket maintenance being insufficient?
What I've been doing for the last 6 months is periodically giving a good wipe down of the various cogs and the chain and then relubricating with some Finish Line Teflon spray (which I've just noticed whilst typing this may be Dry Lube, which I hadn't realised before!).
I've purchased a chain cleaner - Wiggle | Park Tools CM5 Cyclone Chain Cleaner Bike Cleaner and also some new lube - Wiggle | Finish Line Cross Country Lubricant 2oz Bottle Lubrication
To illustrate why I'm asking here, I'm the sort of chap where if this were a car I'd have toddled off down the garage and handed over the keys, but I haven't yet sought out anyone who can service a Kalkhoff near Bristol (and I'm 18 miles away) and I use it to commute every day so if I can sort it myself it will be ideal.
Thanks for reading, apologies for length.
