You could probably soften the glue using a heat gun? But you might discover knackerware preventing battery replacement.i still have my old display just incase as it will die as fk n glued together so no way to change the batt in it
The mad things is, a passing iDevice can sabotage the bluetooth connection to your device and fsck off. Happens all the time to my bluetooth printers, especially the expensive ones.reset the phone and works again now tho never done that b4 and when they turn that server off it wont work at all anyway
Nah, heat gun, plectrum wedged in, and plastic prys will probably do it. Avoid overcooking - very low heat setting only. I usually use the heat gun for shrinking heat shrink. Also, look for hidden plastic tabs and catches, and screws hidden under labels etc.the only way to get this thing apart is with a hammer
