Check this out from Bionx.
SeaScape Watercraft | pedel powered personal watercraft | Powered by BionX
Boat speed with displacement hulls is related to length, so at around 12' that 5 knots is about the limit.Would be great for bimbiling around poole harbour - though for some reason I thought it would be faster.
Not really Ed, see my reply above, only moderate power is needed to achieve water displacement maximum speed for a given hull length. Any attempt at using power to displace the water above that speed results in digging a bigger hole in the water to fall into, plus cavitation bringing risk of destroying the propeller blades.As soon as you're trying to move water out the way rather than air, you need to much more power. I don't think batteries are the answer the that...
