I'm hoping a few of you will be able to help with this.
I'm contenplating using LIPO as a backup battery now that my 36v Battery is backup and running.
As I never use over 3amp's on any one journey on my commute I've been thinking of buying two 6S 5000mah lipo bricks (22v each). Placing them in series and using them on the bike. I also have a Watts up meter installed so I can monitor the Voltages and Amp usage.
LIPO is also avaliable locally sourced so I dont have to wait around and also allows flexiblilty to add parallel packs should I want to increase range in the future. Its also very light and has a high "C".
Would I be right in saying I could litterally buy two lipo bricks. Attach them in series and use them on my Ebike. Also use a 6s charger and charge each brick seperatly or connect them in parallel and charge them up?
Any help is appriciated
Espcially as LIPO can be a bit dangerous if over charged. But I would really like to learn more about these batteries as the weight and flexibility of the packs is great.
