Hi,
I have a trek 7300 which I want to convert to an ebike.
Having looked on the forum there are a lot of ebike kits.
I currently have a powcycle salisbury which I plan to keep as a back up bike.
Now for the Trek I want a front wheel motor which is a lot better than the Salisbury in terms of pulling power and top speed but it also needs to run at least as quiet as the salisbury. I am confident that I could build it as long as there are sufficient instructions and when I do get stuck I am sure the forum will help.
Which kit would users recommend ? I have looked the bafang kit on BMS battery but am not sure which one I need.
Also if I buy a motor with front brake disc, will I be able to change the front brakes to disc?
The trek has a triple chainring will I be able to keep this when I convert it to an ebike or does it need to be replaced to s ingle chainring?
Also how different are the front wheel motor ebikes when compared to the rear wheel motor ebikes is there a great difference to the ride quality?
