80% charge after short time with Lipos?
shambolic
111
27
66
Hi all. I know that most Lithium batterys charge up to 80% fairly quickly. Is that the same with Lipos? What sort of time span would it generally take to get to 80%?. It would be really useful to know this. If I go somewhere and plug in for a few hours it would be very useful to know the battery charge life from thereon .
mountainsport
1,419
298
Firstly, that really depends based on a few factors.
MS.
KirstinS
3,224
899
Brighton
The short answer is Yes to 80% faster than the last 20%
But how fast depends on your chargers capability to pump electricity into your battery (ie what amp rating is it ?)
And how much electricity your battery needs to be 80% full (ie what aH rating it is)
If you have these figures you can make a good estimation
Reactions: mountainsport
shambolic
111
27
66
ok , I am very electronics illiterate so I will type up what's on the charger.
50/68hz 130w DC output +54.6v ...then there's a line with - - - below it followed by 1.8A. The battery is 48V 14aH
KirstinS
3,224
899
Brighton
Hmm doesn't sound like a lipo battery to me
Sounds like a more standard ebike battery eg liMn
It's a 13 cell series battery at 48v nominal. 54.6v is the charge voltage and pack voltage got off the charger
A 1.8amp charger is pretty low powered/slow. Especially for a fairly big battery like yours at 14ah
A basic calculation would be something like 14/1.8 = 7.75 hours
Add say 15% for inefficiencies of the charger and you get 9hours
80% of that is 7.2
So a rough guide would be 7 hours for a 80% charge from empty
This is back of a fag packet stuff mind !
shambolic
111
27
66
Thanks for that
I have a feeling it may be more efficient than it says. it has taken about 7 hours to get from run down to full. Is it possible to get a more efficient charger?
Something puzzling me in the above calculation is the 80% doesn't seem to be any faster rate of charge?
KirstinS
3,224
899
Brighton
Ahh it's nota efficiency thing it's more that the battery won't have 14ah of actually useable power. Once it gets down to about 3.2v per cell the BMS should shut it down
Also I didn't bother with any tapering of charge as I can't guess what that might look like. And the taper wouldn't kick in till after the 80% mark anyway
However If you know from experience it's 7hours to full then I'd guesstimate about 4.5 hours to 80%
You shouldn't charge to only 80% except when you have to because there will be no balancing. The balancing happens during the last few percent when the bleed resistors are switched on.
It would be OK to charge to 80% a couple of times, but if you did it every day, the battery would go out of balance.
You can charge any lithium battery at 0.2C, which is 2.8A for a 14ah one. 3A is close enough though.
shambolic
111
27
66
It's only if I go out on , say a 10 mile trip to visit someone, then I have to charge at theirs to ensure I can get back. So are all Lithium chargers the same? If I get one with the same spec but 3A, will that work, and be safe?
It will have to be the same voltage: 42.0v for most batteries; around 43.5v for LiFePO4.
KirstinS
3,224
899
Brighton
Good point ! Hadn't thought of that
D8ve
2,142
1,294
Bristol
You have a 48volt 14amp battery and you can't get 20 miles out of it?
What sort of bike do you have?
mountainsport
1,419
298
Spot on Mr Dave.
MS.
shambolic
111
27
66
I can get twenty miles out of it. I just like to be sure. I don't pedal much, I can't.
