Yeah I know about them
I've got a sample order on their way to me right now and if they meet the specs I'll have a batch of them.
They'll be competitively priced and put into assembled packs with a proper case, charger, as high a rated BMS as you require (80A cont is no problem). Just cells is possible but I'm much happier doing a proper job to be honest.
However these are not cheap cells and although they have really amazing specs, they are more than most people will ever need. A single 20Ah cells can output over 2500W and a 36V 12 series 20Ah pack can output 600A and about 30,000W, for 2mins
The power density is more than 5KW per kilo. The energy density is 123.75whrs/kg for the 15Ah and 137.5whrs/kg for the 20Ah. These figures are far better than any other available LiFePO4 and comparable to Li Po but without the asociated hazards or the short cycle life, plus it's not cheap. They also claim to have a cycle life of 10-15 years.... Too good to be true? Well the previous A123 cells delivered, so there's no reason to believe that these will not do the same after 3 years of further development. Here's some sizes and weights and don't forget these are 3.3V nominal and not 3.2V like standard LiFePO4.
Model: AHP 70165227 Model: AHP 68150211
Capacity: 20Ah Capacity: 15Ah
Size: 7.0X 166X227mm Size: 6.8X 150X211mm
Weight: 480g Weight: 400g
Once I have the sample cells I'll try to get them tested ASAP. I've ordered the parts to make a resistive load made up of 20 * 0.1ohm 150W resistors that will be switched in as required to confirm the 450A and 600A output of the 15Ah and 20Ah cells respectively. Battery analysers that can accept 600A are rather expensive so this will have to do for the C rating aspect of the tests. They will also be independently analysed with computerised battery analysis system.
I'm rather excited
