lol The generater idea has been deployed by BMW in the i3 as a range extenderYes. Here's one, the Giant Lafree having a Panasonic crank unit to which the owner has added a Heinzmann front hub motor.
He could have switched the Lafree battery to supply either one or other, but in this case he's been cheeky and added a tiny petrol generator on the carrier. I think a second battery would have been more practical, allowing individual or combined use:
How long have you had this battery for Dave and what is the most mileage you've gotten from it ?
The 30aH one belongs to Saneagle. I made it for him out of scrap LiFePO4 ones that I acquired. I had to mix and match lots of cells from different packs to get all the best ones. I then added a 40A BMS from EVAssemble and Bob's your uncle. We've never been anywhere far enough to test it with normal riding, but I reckon it should do 90 miles of normal bike riding since you can get 30 miles out of a 10aH one. It has 1080 watt-hours, so those people that can get 40 miles out of a Bosch battery, should be able to do over 100 miles.How long have you had this battery for Dave and what is the most mileage you've gotten from it ?
MS.
That is good stuff but with three motors and the battery it must weigh a ton. At the end of the day I assume it was initially designed for road use only and knowing you a Saneagle that bike must be running at least 99.9% efficient. Ninety miles though Dave will definitely make you constipated for weeks so I can see why that challenge has not been taken up yet.The 30aH one belongs to Saneagle. I made it for him out of scrap LiFePO4 ones that I acquired. I had to mix and match lots of cells from different packs to get all the best ones. I then added a 40A BMS from EVAssemble and Bob's your uncle. We've never been anywhere far enough to test it with normal riding, but I reckon it should do 90 miles of normal bike riding since you can get 30 miles out of a 10aH one. It has 1080 watt-hours, so those people that can get 40 miles out of a Bosch battery, should be able to do over 100 miles.
