adjust brakes
billyboya
974
88
72
uk
Hi all Im not very good at all this but looking at this photo of my back brake, whats best way to adjust this, as at the moment its not pulling brake on. obviously the wire attached to lever moves to the right when pulling on brakes, but i cant seem to find how to adjust them
31614
2,674
Main problem is a nut missing where the cable goes through the left side rotating arm (left of the spring). That means the cable is not pulling anything.
When the nut is in you have course adjustment by (a) loosen the nut, (b) pull cable through, (c) tighten the nut.
Fine adjustment where the cable goes through the fixed post on the right (right of the spring). (a) back of the right hand (lock) nut, (b) adjust with the left hand nut (the nut next to the post), (c) retighten the lock nut.
Often a good way to adjust is first to get the course adjustment about right. (a) loosen the course adjustment nut, (b) arrange the fine adjustment to half way, (c) course adjust, pull the cable as tight as possible with the left rotating arm pulled to the brake engaged position, (d) tighten the course adjustment nut. The brakes will now be locked on.
Now back up the fine adjustment so the brake is not locked on, but a smallish pull of the brake lever engages it.
When doing adjustment make sure that wherever brake cable outer segments end the cable outer segments are properly seated. This applies especially at the brake lever.
WavyDavy
19
15
There seem to be few nuts and bolts missing. There should be a nut and bolt anchoring the torque arm and also a nut and washer on the cable clamp. Once the cable is clamped and the spring on the little nib on the lever you can adjust the brake with the adjuster on the end of the outer cable.
8,226
Tbh looking at the state of the few inchs of cable we can see I would change the outer and inner completely and start a fresh.
As been mentioned the rear securing nut for the cable clamp is missing until that is replaced the brake will never work, the item WavyDavy has mentioned as a T/A isn't it is part of the hub brake mechanism. It looks like a bolt is required to hold the end of the mechanism's arm to the cable adjustment bracket this also will hold the bracket in place to prevent it moving. Once you are sorted also get some aluminium cable end ferules to crimp on to the wire to prevent fraying.
The wire clamp bolt on the end may need a new one as the thread may well be damaged.
billyboya
974
88
72
uk
Hi all many thanks for your help, Regarding
thats my fault as I had removed those to give it a go no nuts bolts are missing, what you said here WavyDavy
I have enclosed a picture below where the red arrow is pointing end of spring goes onto where yellow arrow is. and do you mean where blue arrow is
31617
billyboya
974
88
72
uk
Hi sorry to ask this but I am a bit confused with all you are saying. would it be possible if you could edit my picture with arrows like i have to explain. sorry Im no good at all this
This is how it look at the moment but I think its wrong like that. I will of course get a new cable but just need to fix brake temp for now so at least I have a brake
31619
8,226
The spring generally shouldn't be under so much tension/compression as in you pic above. Use a combination of winding out the adjuster screw and the brake lever adjustment to arrive at a point where the brake works well.
I would start by undoing the cable clamp bolt , wind the rear adjustment screw in and also wind in the lever adjustment. Then tighten the rear wire clamp bolt with less spring compression and try the brakes. From there on you need to make adjustment's for good brake feel/stopping ability.
For lever travel use the lever adjustment and for rear brake bite use the rear adjustment screw.
Once you get it working satisfactory then you can renew the inner cable.
billyboya
974
88
72
uk
The spring generally should be under so much tension/compression as in you pic above. Use a combination of winding out the adjuster screw and the brake lever adjustment to arrive at a point where the brake works well.
Thank you so much without this site I would be lost on my electric bike I know its an old bike but as long as it gets me A to B Im ok with it. maybe will invest 1 day in a modern bike. its most helpful with these forums. thanks all
2,674
Looking more carefully I had the fine adjustment the wrong way round. I'm pretty sure the main adjustment is the right one and goes right through the arm that holds it; the left one is the lock nut which should be turned tight against the holding arm once the adjustment is complete.
31620
8,226
You may have to be patient with getting good brake bite & lever travel/feel so it may take several attempts of adjustment to get it working quite well.
Not forgetting that generally the front brake usually does about 70% of the braking, the rear should work well with out it locking up completely.
billyboya
974
88
72
uk
Well I just took bike for a test run, and yes back brake, needs a bit more adjustment will adjust again
