Need to find equipment? Ask JamesMe. too. Thanks for the info, been looking for something like that for ages
Pete
Pete
Sorry - given the amount of equipment that is already on the right hand side of your handlebar, I have probably misled you.James
Just received my grips Velo Ergogel D3 Lock Handlebar Grips Ergon
My throttle is on the right hand side( twist) I would need to cut the new short grip down by around 1 1/4" to keep the throttle/battery meter, brake lever and gear shift where they are at present. No problem cutting it down as unlike the full length left hand grip that has a metal inner right to the end the right hand short grip is just the rubber with a plastic inner tube.
OK so far! cutting down the short grip would leave only the raised section of the grip as I would be cutting off all of the standard round section (does that make sense?)
I don`t think it would lead to problem, what do you reckon?
On the otherhand If I fitted the short grip without cutting it I would have to move everything along. No big problem with that other than because the new grip is that 1 1/4" longer than the existing it would move the front brake lever in by that amount.
You might say that it wouldn`t make any difference because in reality the position of the brake in conjuntion with the throttle and the first unraised section of the new grip would be similar to using the exisitng grip but having your hand out on the end of the bar using the raised section of the new grip for the proposed comfort that it might offer will make it more of a jump across to grab the front brake lever rather that just extending your fingers to grab the brake lever.
I think I`ve explained it for you to understand what I`m getting at.
The snow cleared from the roads just enough for me to get around a 6 mile test run. A couple of on the road fine adjustments to grip angles and brake levers and I think I`ve got it just about right.James
Thanks for coming back
I removed the old grips, shifted everything in to accept the new grips without cutting, fitted the grips without any cutting temporary.
Images here e-bike Photo Gallery by david chilvers at pbase.com
To be honest resting my hands in the position that they would have fallen in for braking and it seems very normal( as it would) holding the grips towards the outer limit where you would use them for max comfort and wrist support and I can still easily get my hands to the brakes ( I have fairly large hands)
So it would seem that even in an emergency I would still easily apply the brakes and if I were travelling fast downhill( chance would be a fine thing) then my hands would probably be away from the outer edge with full set of fingers on the levers. I just set it up to test so nothing lost. although I`ve cut the old grips off there is no problem because they were hard and horrible and after feeling the new grips I would never go back.
Road test yet to do and fine adjustment to angles etc but i see what you mean about the new grips, they are very comfortable and definitely keep your wrist more in line with your hand which I would think can be part and parcel to avoiding numbness on it`s own.
I`m glad I didn`t cut the new grips, I think they will work fine because the way my hands lay on the bars anyway they tend to be slightly pointing towards the centre of the bars.
Sorry about the poor images as I didn`t have time to set up any decent lights.Take a look at the images and let me know what you think.
Thanks again and Merry Christmas to you and Yours
Dave
