Assist levels
Atlav4
179
75
Quick question, my display the kd85c can’t be put into zero assist and still display speed etc. but the amount of assist in each level can be changed so the question is will i cause any issue by setting level 1 at it’s lowest which is 10% then level 2 at 50% then increase 3,4, and 5 up to max assist. Only asking as I am hoping to ride with as little assist as possible for as long as possible but still have distance, speed etc recorded on display. Cheers BDDDD629-B5B2-4B71-B6E4-BC697ADE55C5.jpeg
2,838
Not sure if it is possible, but if it is I'd suggest level 2 much lower, say 30%, then 50, 70,100 or similar.
Atlav4
179
75
Thanks sjpt pretty sure the 5 levels can be set to your desired range. But a bit worried that having level 1 to what is minimum ie 10% may mess with controller/battery as I’ve noticed voltage is set for each level or current for each level, not sure which.
