Bafang 250w Vs 500w
Wayners
491
103
56
Gloucester
What is the difference between
Bafang G.010.250.DC and the LG.020.500.DC
Are they different internally?
I'm thinking of getting the 250w and running 48v through it.
17,244
Bafang make those two motors differently, their 36V and 48V versions differ too.
There are trade-offs, you should buy exactly what you need and avoid using the component outside its specifications.
There are always trade off, there is no free lunch.
Reactions: Wayners
Wayners
491
103
56
Gloucester
I love to strap a 1000w hub with a 52 volt battery on my bike and tow a bike trailer. Tomorrow I'll have my rear rack bag full. IKEA bag full of dust sheets over my shoulder plus ruck sack bag full of tools and my lunch. It's a Monday so I can add a bit more leg power on my commute to work along canal cycle path. I need power tbh. @Woosh 48v bafang rear hub is what I need I think.
I was looking at a roll of shed felt I needed to carry last week but decided against it. Too much weight on a bike. Was going to ask If others carry lots . I've seen some campers loaded up on ebike.
17,244
you don't need as much as 1000W to pull a trailer with 100kgs load. The issue is to avoid running the motor outside its sweet zone.
This Woosh Big Bear is fitted with a Bafang 36V 20A 250W BPM motor:
Reactions: Wayners and EddiePJ
6,722
get the 1000w 30a one i cant fkn beat it :p
8,754
Over 180lbs load not inc the trailer pulled gamely by a 250w Bafang G370 1.6kg front hub motor 201rpm @44v and no throttle in sight.
This is on the Worth Way the old Three Bridges to E.Grinstead line now a traffic free bridleway.
500w /1000w will only be better if you throw more current at them and a good battery capable of 40a continuous .
53354
8,754
My Ute longtail with 250w tsdz2 @44v also tows the same trailer with ease.
