Bafang BBS02 mid drive
gwp58
7
Hi
I have recently converted my Norco Threshold using a Bafang BBS02 mid drive 36v 500w. I also have a Trek FX hybrid which i converted with a rear hub motor again 36v 500w.
I am finding that the battery drains quickly on the Norco far quicker than on my Trek.
The batteries are Hailong 36v 15.6 ah and a 36v 15ah
The hub motor on the Trek allows me to commute to work for 2 days approx 16 miles per day so about 32 miles before charging the battery.
The mid drive on the Norco allows me to travel around 24 miles before it is drained. Is this normal?
The specs are:
Trek 21 speed 11 - 32 48/38/28 crank
Norco 10 speed 11-32 46 tooth crank
Both have thumb throttle but i only use this to occasionally set of from traffic lights i pedal and use pas level 2/3 but sometimes use level 5 on steep ascents.
Any ideas why the mid drive drains the battery quicker
2,835
Could be down to the controllers? Which do you have?
gwp58
7
The Bafang is a C 961 controller and the Hub motor is a KT LCD 3
8,755
Those aren't controllers but displays/LCD's.
The controller id the pcb/brains of the bike, what are the current rating of the controllers ?
3,994
If you completed the journey on both bikes in the same time with the same pedal effort, the range should be more or less the same. If you complete the journey in less time on one bike, then that one should drain the battery faster.
The next consideration is whether you're using the Bafang efficiently. you get more torque from it when pedalling slowly, but that's not very efficient. You need to keep pedalling over 60 RPM. I'd guess that around 75 rpm is probably the most efficient.
Can you easily swap the batteries over to eliminate them from the equation?
Apart from the range, which motor do you prefer and why?
gwp58
7
The hub motor is rated at 20A the mid drive is 25A
gwp58
7
Hi Vfr400
i have swapped over the batteries and it does not make much difference.
The hub motor seems smoother on take off compared to the mid drive seems to launch then top out.
I run a Garmin edge 510 and see the data live so my cadence is usually between 70 - 85 rpm
The hub seems to give a higher top speed this may be due to the difference in gearing, the mid drive as you say is more torque'y
At the end of the day it gets me out riding its just frustrating the mid drive eats more power
8,755
Has the BBS parameter's been changed at all by programming.
Fordulike
3,802
1,538
Solution, use a programming cable to tweak a setting or two, then enjoy.
I'd start by dropping current limit down about 5 amps on the 'Basic' tab, in the programming software.
Reactions: gwp58
