D djneils98 Pedelecer Jun 8, 2021 68 15 Aug 9, 2021 #1 can the BBS02 be used with a 52v battery or does it have to be 48v??
V vfr400 Esteemed Pedelecer Jun 12, 2011 9,822 3,994 Basildon Aug 11, 2021 #2 What are you hoping to gain by running at 52v?
D djneils98 Pedelecer Jun 8, 2021 68 15 Aug 11, 2021 #3 bit more power I guess particularly when the battery isn't fully charged or cold
Fordulike Esteemed Pedelecer Feb 26, 2010 3,802 1,538 Aug 11, 2021 #4 To be honest, the difference will be negligible. You'd get much greater results by using a programming cable to boost power.
V vfr400 Esteemed Pedelecer Jun 12, 2011 9,822 3,994 Basildon Aug 12, 2021 #5 djneils98 said: can the BBS02 be used with a 52v battery or does it have to be 48v?? Click to expand... If you want more power, get a BBSHD. It's a much stronger motor.
