I have been experimenting with various battery options on my Nano Brompton including the standard 36v 7 Ah Li Po battery and a much smaller Bosch 2.6 Ah 36 v Li Ion powertool battery.
Both batteries take up too much room in the pannier bag, although I have also made a battery holder for the Bosch battery to go in the rear pocket. Sadly 2.6 Ah isnt quite enough for the range I require although I have considered mounting another battery in the other pocket which would presumably give me 5.2 Ah which is more than enough range. By the way can anyone tell me how I wire 2 batteries together so as to double the Ah but not the voltage - do I just join the 2 wires together at the controller? Do the batteries have to be equal size i.e. could I connect a 1.3 Ah and a 2.6 Ah?
The Bosch batteries recharge in 40 minutes from flat which makes them quite attractive although they do have to be removed and inserted into the charger which is a little inconvenient.
As this is a folding bike, battery options are also linked to luggage options and I have now concluded that what I actually need is a battery that will fit in a briefcase/laptop bag as well as a laptop and papers. The ideal shape size for such a battery might in fact be the shape & size of a small laptop.
The standard Brompton front pannier bag isnt really large enough to do all of this, certainly not with a 7 Ah battery and isnt really suitable to take to meetings so I therefore intend to modify a laptop bag or briefcase to mount on the Bromptons luggage block (probably using the Brompton luggage frame) with all the wiring connnectors built in.
Whilst I am a fairly competent DIYer I am not sure that making a battery is within my capability from the technical knowledge aspect and I therefore need some external assistance in the form of a company or specilaist who could do this for me. What I might also consider is having the existing 7Ah battery dismantled and reassembled into a new case although I dont know what cells are inside as the case is glued together. Alternatively a completely new battery of the right size, as light as possible of at least 5 Ah.
Is this battery proposal feasible i.e. a large thin battery and is there a company/specialist I could ask to build it? Are there standard battery cases or does this have to be made?
Any help much appreciated as always
Francis
Francis
