Battery Connectors
bill_s
10
View attachment Battery Connector side view.bmpView attachment Battery Connector angle view.bmpView attachment Battery Connector socket view.bmp
Hi,
I want to purchase in-line battery connectors for my project ebike.
I want to use the same type as my charger plug (see attachments please).
The diameter of the plastic section is 12.5mm and the length of the metal body plus the plastic section is 28mm.
The connectors are similar to 3-pin power DIN plugs (Maplin N83KT & N84KT) although the pin spacing seems to be slightly different.
Can anyone help?
Thanks, Bill.
muckymits
419
They will melt on full load. Charging is only using 5 amps max, but the bike is using well over 10 amps on the road. You will need heavier cables to the controller with decent connectors on, I use XT60s.
