B
Brannenthompson1
Does anyone know the standard for a 15ah battery what is the 15ah ie all batteries are sold in amp hours but what should you get when using it on your E Bike for instance I seem to be getting about 9ah between 42 and 32v but if I had a 10ah battery would I only get 6ah as in two thirds of the stated amp hours or should you get the full 15 or 10ah that are advertised between 42v fully charged and 32 volts minimum. The question is should I see 15ah being used between full charge and 32volt cut off? Is there an industry standard for the usable amp hours a battery makes. Its driving me crazy Because my watt meter is telling me I'm using around 9ah between full charge and 32v, I have a 36v 500w hub motor with 22amp max controller my battery specs are
Nominal Capacity 15 Ah
Nominal Voltage 37 v
Cell Inside Li-ion 3.7V 2600mAh
Configuration 10S5P
Standard Charge Current 3 a
Max. Charge Current 15 a
Protected Circuit Board(BMS) GLBR-Li10S1505-BMS
Continue Discharge Current 15 a
Peak Discharge Current 30 a
Full Charged Voltage 42V
Charge Cut-off Voltage 42.5V
Discharge Cut-off Voltage 25V
Battery Net Weight 3.7 kg
Life Cycle 800
Configuration 10S5P
Life Cycle 800
