Help! Battery lock jammed
Kizza
101
35
London
My Cube ebike battery is currently stuck on the bike because the release lock is jammed.
I've tried powdered graphite and GT-85 spray but no luck.
Any suggestions? If I drilled the lock out, would the battery still affix safely in the cradle?
dalemanuk
10
uk
Had the same problem last year. I tried GT85 and all the other stuff but no luck
Eventually I washed out the lock with brake cleaner, dried it with an airline and then just kept working the key in it whilst tapping it gently with a hammer. It gave in eventually and opened. Plenty of bump key videos on youtube to give you ideas
I dismantled it afterwards but couldn't really see anything wrong but I chucked it anyway and got a repalcement
georgehenry
1,455
1,273
Surrey
When my Yamaha battery lock became difficult,probably after getting some grit in, my bike shop suggested laying the bike on it side and dribbling a good general oil like the old 3 in 1 oil generously into the lock and then leaving it like that for a while.
I actually used a different quality oil I had on the shelf, and was pleasantly surprised that this trick worked for me.
Reactions: Kizza and jokskot
Kizza
101
35
London
Thanks for the replies. I took it to the local locksmith who spent half an hour trying to free the lock. Eventually had to drill it out, which took another 10 minutes! Nice chap, only charged me a fiver.
Looks like a replacement lock is about £20.
Reactions: RoadieRoger
Kizza
101
35
London
I probably should have tried this first. And I probably should've kept the lock more lubed over the last few years.
