The Wisper lock is quite well designed and will need force to bypass it, as the frame can be cut through easily then heavy locks are a little pointless. The seat tube doesn't extend above the top of the battery so there isn't much you can attach a padlock to. I recommend you wait until you have the bike and then work out what will be good, that is likely to be either trust the Wisper lock or don't leave the battery in the bike.I know the Wisper has its own built-in lock, but I was thinking of putting a 'proper' Squire-type lock on the frame above it, on the reasoning that the Wisper lock is probably fairly easy to bust, whereas the Squire-type lock (£50 plus for a sodding padlock, mind), isn't...
Allen.
I've had people try to steal my whole bike or just components of it and I have lost a few accessories that I forgot to remove, this is all on a busy road in central London. Thieves often think of new tactics to relieve you of your pride and joy but fortunately most thieves are just opportunists or stupid, which is just as well as most locks are rubbish.Fair enough, mussels - I wasn't going to buy it till I saw what I was up against. I think the yanks call it getting all your ducks lined up.
A.
