Battery Pack Again
mygrumpy001
Hi All 4 25c 2700mah 3SIP 11.1 tested with Multimeter 38.5v on bike 25.32 something wrong any idea photo to follow Thanks For Any HelpIMG_2190.JPG
Alan Quay
2,351
1,076
Devon
At he risk of repeating myself, that's correct for the 2S2P arrangement that you have created. This will give you a nominal 21.6v pack (which will measure around 25.2V fully charged)
mygrumpy001
Hi Alan So why does it read 38.5v on Muiltmeter so what needs to be done mygrumpy001
Alan Quay
2,351
1,076
Devon
I don't understand what ' tested with Multimeter 38.5v on bike 25.32' means. Please elaborate.
8,773
When connected on the bike you have 2s2p as Alan states so 2 in series then paralleled or vica versa to get 25.32v which is more then 4.2v per cell. I guess the 38.5 reading was before you connected them up on the bike but sounds like you have connected only 3 in series to get that reading or if you wired them all up have connected them wrong to get that reading. So I assume you are running a 24v set up so your 2s2p lipo is not really much good as 24v is usually 7s @ 29.4v.
You need to be careful with charging and connecting lipo other wise you will have a fire after the bang. I only charge to 41.5 per cell and even then there is little use to be had at that reading on a bike and very quickly on the bike voltage drops quickly to under 41v. The last 1v of charge upto 42v contains as little as 3 or 4% of total capacity.
Alan Quay
2,351
1,076
Devon
I have assumed his packs are 3s1p, (10.8v nominal, 12.6v charged) then he has arranged those packs as 2s2p, giving a total of 6s2p.
Sent from my HTC One_M8 using Tapatalk
mygrumpy001
Hi Alan This is getting a pain for you and me on Scriptasylum.com it has a bar in the middle is that wright John
