I have a battery of 13 packages in serie consisting of 3 paralell cells each. The battery has been exposed to water and will not function. The charger stops charging after a short time and the light turn green. I have tested each of the 13 packages with voltmeter and it turns out that all but one has uniform voltage. The 12 packages are measured to 4,05v while one is 3,75v. When I try to start the display the current and voltage drops and the display shuts down. It seems that the one 3-cell package is low voltage - although not critical - but I am uncertain about the reason.
Is it the BMS that is not working properly or is the cell package damaged?
Is it possible to change single cells in
If a shortcut caused by water has made one of the 3 cell-packages drop voltage I wonder if it is posslible to do an isolated charge of that package or if it is preferreable to discharge the other packages in order to even voltage levels?
Links
BMS: http://www.bmsbattery.com/bmspcm/566-10s-lithium-ion-bms-for-bottle-battery-case.html
Battery: http://www.bmsbattery.com/48v/248-48v-10ah-lithium-ion-electric-bicycle-battery-pack.html
Links
