Battery weather tight
cyclenut1952
278
29
Leeds LS27
Hi
I am looking to purchase an ebike.
The type that have the battery down behind the seat post, are the bottom connections totally sealed? or can water collect there and cause problems?
KirstinS
3,224
899
Brighton
Hi
General rule of thumb is that you can cycle an ebike in the rain no worries.
But they don't like being left standing in rain much
More common than batteries with water ingress are lcd panels. At least that's how it seems to me from this forums users anyway
8,746
Nothing is totally sealed with external batteries, as K has said they are ok for riding in the rain. Issues appear when left in standing rain for hours on end or the user decides to use a hose pipe or pressure washer. If bothered you can add a small dob of grease to the contacts.
For the display you can cover it with a bag for instance if you use the bike for shopping when it rains and have to leave it a while.
mike killay
3,012
1,629
I have used evostick to seal where any cable goes into a device.
For the LCD display I rubbed grease into the joint between the clear plastic face and the casing. Also, I set mine slightly loose on the handlebar, so in bad weather I can turn it upside down.
8,746
Although unfashionable a bike cape for riding or a bike cover for when it rains and left locked outside.
Reactions: mike killay
KirstinS
3,224
899
Brighton
I also use sugru for various jobs incuding this
And, as I used to travel a lot for work in UK, a large stash of shower caps from hotels. I always keep one in my bag for really horrendous weather to stick over the the LCD
It was a tip from an ex member!
KirstinS
3,224
899
Brighton
Has anyone ridden with a cape, when I tried decades ago it was caught by the wind & billowed around
Yes I have, I tend to either ride fast as a commuter or off road mtb. It doesn't really suit either tbh
However for what you might term utility cycling they are absolutely great
Decathlon sell them BTW, or used to a few months bsck
Edit. Still do
3,994
When I commuted, I used to use a cape. Yes, you get blown around a bit when it's windy, but it's manageable and at least you and your bike stay dry and comfortable. Before the cape, I tried just about every other type of waterproof. Considering everything, I think the cape is the best solution, and it protects your bike too. Plus, you can use it as a bike cover if you have to park in the rain.
2,830
When I commuted (only 5 miles, and 250 ft climb each way, non ebike, 1/2 off-road in summer, all on road in winter) I used regular waterproof top and trousers. My contribution to lack of fashion was welly boots, surprisingly comfy to ride in and no risk of water being dumped in from trouser bottoms.
I never tried a cape, though, so can't compare.
mike killay
3,012
1,629
I do remember police officers on cycles wearing capes, so they must be good.
The difference was though that the Police cape was a heavy woollen affair that did not blow around. As a teenager I had one of the traditional oil cloth capes, less likely to blow about, but after a year or two, it turned into a sticky glutinous mass!
Nosweat
90
29
Do they still make oilskin capes? Mine is around 30 years old and needing replacement fairly soon. It weighs a ton (well, perhaps a couple of kilograms) but that's what makes it so good - it doesn't flap all over the place in the wind like the flimsy polythene capes you see nowadays that make people say capes are a waste of time. I tried one and threw it away - the old fashioned ones are brilliant.
