bh bike
geoffthehare
Jul 31, 2019
hi i've had a bh evo cross for 2 years and the motor has just died, i can't believe it, a 2 grand bike, that was regularly serviced and the motor packs up, anyone else had that problem , i have to say trying to tried it without power, difficult !!,
geoffthehare
Jul 31, 2019
the screen shows a fully charged battery, the pedals are impossible to moved, there is no power on the rear hub
Benjahmin
2,653
1,778
70
West Wales
I'm assuming this is a rear hub motor?
Put the bike on a stand. Turn off the power. Try to turn the motor wheel, if it will not turn or is very difficult to turn, disconnect the motor from the controller. There should be a plug somewhere near the motor. Try to turn the motor again. If it turns (forwards should be free, backwards will have a slight resistance) then the controller is faulty.
geoffthehare
Jul 31, 2019
HI thanks for that obviously an expert, i just took it back to the shop its still under warranty , sod it ,let them sort it out ,cheers
8,746
The bike although rear hub utilises a TS BB so issue may be the TS system.
OP is correct though ,it is under warranty so the dealer should sort out the issue.
