Hello.
Would I be correct in thinking that if I have a 3000 watt motor and a 52 volt battery then according to the formula Power = Voltage x Amps - 3000 watts divided by 52 volts = 57.69 amps that the battery bms would need to be 60 amp or above ? or are there other factors that need to be considered ? If I tried to use a battery that only had a 50 amp bms, would the bms cut the battery out at some point when riding ?
Thanks. Ian
Thanks. Ian
