Bosch E battery for Kalkhoff Pro Connect
Trood
Oct 25, 2022
Does anyone know of a functioning battery which could be used not necessarily new?
6,722
you could try ebay for a 2nd hand one but make sure it has been tested to see how many charge cycles it has had b4 you buy one but only a bosch dealer can do this.
AndyBike
1,698
728
Can you be more specific. Internal ?,external. 300/400/500/625wh
As above though, usually ebay or a general google can bring something up.
Black friday/cyber monday coming up so maybe get a better price if you are lucky and hold off till then.
Im of the opinion that if you stick a £1 coin in a jar each time you do a full charge, and most batteries list as being good for at least 500 full charges(more or less), then when you reach that limit, you will have most of what the replacement costs saved to buy a new replacement battery.
Of course im rubbish at following my own advice
borsche is antichrist
:rolleyes:
AndyBike
1,698
728
I should remind everyone not to blindly follow links off 'just joined' especially as its all in Chinese.
6,722
my house bigger than yours scotty :D. borsche useless repair batts
the batts can be recelled and there are 3rd party ones but there will soon be a option in the uk to get these things recelled and not have to send it to germany as only other place that can do it so is possible.
6,722
the new smart frame batts wont even work on any older motors :rolleyes:
6,722
made in germany must be over 15 years old and still blowing :p
AndyBike
1,698
728
6,722
liofit can recell the bosch batts but needs board hacking so can bus hacking as still use the bosch bms and also now peter can do board repair to bosch controllers if it has short damage as long as it is not a part on the pcb he cant buy like a cpu ect
https://www.ebikemotorcentre.com/
  • Useful
Reactions: AndyBike
AndyBike
1,698
728
I have both trousers and a kilt. But thanks for the offer Sanjay.
Reactions: Zompukuwabaramundi
